I am using ultraDayView & view style of ultraDayView is MsVisualStudio2005, that has been set in ultraCalenderLook. Now i m going to print the specific day of ultraDayView using ultraSchedulePrintDocument, but the print preview display the view style in MsOffice2007, but i want the same style which is used in day view. Please help me regarding this issue.
The ViewStyle comes from the associated CalendarLook so if you've set that on the UltraDayView and UltraSchedulePrintDocument to the same CalendarLook instance then it should work. If it doesn't then I would recommend contacting the support group and providing a sample that demonstrates the problem - http://ko.infragistics.com/gethelp/default.aspx.
Hello smith,
Well the property u mention is already set, is containing the same object that is used by the controls. Please help regarding this
Thank you
You should set the CalendarLook property of the UltraSchedulePrintDocument to be the same CalendarLook you are using for the controls.
