2430
How do you define Band Ordering
I have an UltraDataSource that has 3 tables.
Say Table A
Table A has 2 children B and C.
So I attach grid to data source I see 3 bands with A and two children B and C and B is above C in band order.  Since B and C are on the same hierachy level, I would like to specify band C above B rather than vice versa.
Rather than A = Band 0, B = Band 1, C = Band 2, I would like the it to be A = Band 0, B = Band 2, C = Band 1
  • 469350
    You could also do this using the VisiblePosition property on the grid band.
  • 2430
    Verified Answer
    Resolved - simply hacked the xsd file and changed the ordering of the relationships in the data source.  I assume this can also be done by deleting the relationships and adding them in the order which will provide the band ordering required (aka assing B to A before C or C to A before B to change the band ordering in the UltraGrid.
