1369
UltraChart Series and DataPoints?
I had this learning curve on infragistics wpf controls.  The xamChart allows to create multiple series and datapoints within at runtime.  Then you can assign each datapoint an x and y coordinate, and radius and you will have your scatter point on the chart.  How do I add these scatter points in UltraChart?
  • 26458
    The .Net chart doesn't have a notion of ChartParameters, like the WPF chart does. In order to add a series for a scatter chart you need to:
    Create a new XYSeries
    Add new XYDataPoint instances to the series.Points collection
    Add the series to ultrachart.Series collection
    Scatter charts don't use different radii, so if you need to specify a radius, try using a bubble chart instead. Bubble charts use XYZSeries and XYZDataPoints
