20
AlphaBlending Sample
I am using the demo version to evaluate your controls
When using the AlphaBlending.vbproj sample, in the activity alpha tab
The appointments slider does not work and changing the color for the appointments bar also does not work .
The Holidays and notes sliders work fine and I can also change the colors
It is the changing of the appointment colors that I require for my app
Is there a problem with this sample vbproj
  • 8607
    Hello rkwharton,
    Thank you for pointing out this problem.  I passed it on to our sample developer.  It will be fixed in our next volume release.
    To fix it, in Private Sub frmAlphaBlending_Load, comment out the 3 lines below "Load the IG isl File".
    I hope that this information will help you with your evaluation.  Let me know if you have further questions.
    Elizabeth Albert
    Localization Engineer
