105
Determine if node checkbox was clicked on MouseClick
 I have an UltraTree that uses the MouseClick event to determine if a node is clicked.  At this point if a node was clicked, I expand/collapse the node.  I now want to allow for checkboxes, as well as this feature.  The MouseClick fires before the BeforeCheck and AfterCheck events.  Because of this, I do not know how to determine if the checkbox was clicked, and therefore the node is expanded/collapsed when the checkbox is checked.  Is there anyway during the MouseClick event, that I can determine if the checkbox was clicked or the text of the node was clicked?  I don't want the node expanded/collapsed when the node checkbox is clicked, only the text.
 Thank you,
Jake
  • 469350
    Verified Answer
    Hi Jake,
        How are you getting the node to expand/collapse? I assume you must be using UIElements. This is the same way you would determine if the click was on a checkbox.
            private void ultraTree1_MouseClick(object sender, MouseEventArgs e)
                UIElement element = this.ultraTree1.UIElement.LastElementEntered;
                if (element == null)
                    return;
                // If the element is a checkbox, return.
                if (element is CheckIndicatorUIElement)
                    return;
                // If the element is the child of a checkbox, return.
                if (element.GetAncestor(typeof(CheckIndicatorUIElement)) != null)
                    return;
                // Get the node from the element (could be null).
                UltraTreeNode node = element.GetContext(typeof(UltraTreeNode)) as UltraTreeNode;
