how to change header area height without change the text header height and keep the widht of single tab header autosized with its text ?
so i do to modify only the height of header..
thank you
Andrea
ok thanks, I try to change image size
The height of the header area is controlled only by the size of the text and the size of images. If you want to keep your text the same size, you will need to change the height of the images. I'm not sure if this will work correctly and keep your images unstretched, but you can try to set the ImageSize property on the tab control and give it a new height.
