Is there a way to be able to sum a column when there is a dollar sign in front of it?
Hello again,
Did this approach work for you? If not, please do not hesitate to ask anything related to this topic.
I still didn't resolve this. I will try to see if I can determine if the column type is money by using the DataType property on each column and format accordingly.
Thanks.
I am just checking about the progress of this issue. Please let me know If you need my further assistance on this.
Hello bdisk,
I do not see how the grid will sum the varchar field. You would have to make a custom summary by casting the values to double or something like that.
Please do not hesitate to contact us if you need any additional assistance.
Yes, that correct - except its not a money field since theres a dollar sign in front of it, so it's a varchar field now.
Is there a way to sum varchar fields?
(As I've mentioned, the grid columns are dynamic, and therefore I can't just format and add the dollar sign in code or in a designer property.)
