175
AutoFillTime not working on EditorComponents
The UltraDateTimeEditor control has a property called 'AutoFillTime'. When this property is set to 'CurrentTime' the time section in the control is automatically filled in should a user enter a date but not a time in the control and end an edit (i.e., set a format mask to '{date} {time}' in a UltraDateTimeEditor, enter the value 10/10/1950 and tab out of the control and the time will get automatically filled in).
If I use the same control as the EditorComponent for an ultra grid column the same behavior does not happen. If a time is not entered into the cell a DataError is raised.
Is it possible to get the ultragrid to automatically fill in the missing time values?
I've attached a solution that can be used to reproduce the problem.
1) In first drop down enter the values 11/11/1111 and press tab -> the current time gets appened to the value you entered.
2) Click the first cell in the ultra grid, enter the value 11/11/1111 and press tab -> Data Error is raised. Current time is not appended to the entered value.
DateTimeEditorComponent.zip
