I don't know if this is the right place to put this question.
I use a propertygrid to design Netadvantage text boxes, labels,...Users may not edit all the properties of the control so I made my own derived classes (MyTextBox, MyLabel,...) , I have added an attribute type to the properties that I want to show in my propertygrid.So far so good, but the propertygrid may also not show the links "About", "Custom property pages...", which shows a dialog where users can edit all the properties.
Is there a way to hide these links?
Sorry, I really don't know if there is any way to do this. I assume you have tried overriding the About property.
An alternative solution might be to hook up the Property grid to some custom object instead of the grid itself. You could create an class that exposes the properties of the grid that you want and leaves out the ones you don't.
Thanks for your help!
Nobody has an answer?
