Hi team,
I got an ultragrid filled up and contains images and colors on the rows.
The filter does work , it sorts well in the ultragrid.
When exporting to excel , it replaces the color with the name of it and the image is not into the cell, its just floating over the cell, so if I filter or sort over excel the images stays on the same position they appear.
Any idea regarding this,
This is how I fill the ultragrid row color value over UltraGrid2_InitializeRow
If overall >= 9 Then
e.Row.Cells("Top2, Mid4, Bot5").Value = Color.Green
ElseIf overall >= 5 And overall <= 8 Then
e.Row.Cells("Top2, Mid4, Bot5").Value = Color.Yellow
ElseIf (overall <= 4) Then
e.Row.Cells("Top2, Mid4, Bot5").Value = Color.Red
End If
Thanks.
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
As far as I know basic functionality of Excel doesn’t allow cells' values to be Image or Color. Excel works with formulas and functions, which could not be executed onto a Pictures and Colors. So the issue which you are facing comes from the Excel limitations.
