I have an ultragrid which has several columns.There is one column named CERTIFICATE which contains jpg,pdf..etc type of files.My requirement is that if i select a particular row and click button "btnemail" i want that particular row's column CERTIFICATE to be shown as attachment in outlook.Can any one plz help me out
Hello MauryaIsha,
Last year I made something similar in one of my projects, so maybe you could use this approach below:
public static bool SendMail(string MailAddressTo, string MailMessage, string AttachedFileName) { Attachment AttFile = null; string OriginalMailAddressTo = MailAddressTo; try { SmtpClient smtpClient = new SmtpClient(); MailMessage message = new MailMessage(); smtpClient.DeliveryMethod = SmtpDeliveryMethod.Network; smtpClient.Host = Properties.Settings.Default.MailServer; smtpClient.UseDefaultCredentials = Properties.Settings.Default.MailCredentials; if (!Properties.Settings.Default.MailCredentials) smtpClient.Credentials = new NetworkCredential(Properties.Settings.Default.MailUsername, Properties.Settings.Default.MailPassword); MailAddress MailAddressFrom = new MailAddress(Properties.Settings.Default.MailAddress); message.From = MailAddressFrom; // Цикъл по адресите до които ще се изпраща e-mail ако са повече от един разделени с ";" while (MailAddressTo.Length > 0) { int charIndex = MailAddressTo.IndexOf(';'); if (charIndex == -1) { try { message.To.Add(MailAddressTo); break; } catch (Exception ex) { EventLog.WriteEntry(ImsDataExchangeService.sSource, "Incorrect e-mail address <" + MailAddressTo + "> " + ex.ToString(), EventLogEntryType.Warning); } } else { string currentAddress = MailAddressTo.Substring(0, MailAddressTo.IndexOf(';')); try { message.To.Add(currentAddress); } catch (Exception ex) { EventLog.WriteEntry(ImsDataExchangeService.sSource, "Incorrect e-mail address <" + currentAddress + "> " + ex.ToString(), EventLogEntryType.Warning); } MailAddressTo = MailAddressTo.Remove(0, charIndex + 1); } } message.Subject = Properties.Settings.Default.MailSubject; message.IsBodyHtml = false; message.Body = MailMessage; if (AttachedFileName != null) { AttFile = new Attachment(AttachedFileName); message.Attachments.Add(AttFile); } smtpClient.Send(message); if (AttachedFileName != null) AttFile.Dispose(); return true; } catch (Exception ex) { EventLog.WriteEntry(ImsDataExchangeService.sSource, "GENERAL ERROR: It is not possible to send the message to " + OriginalMailAddressTo + ". " + ex.ToString(), EventLogEntryType.Warning); return false; } }
try
break;
else
return true;
return false;
When you press your Button you should call this method. Please provide information about recipient, message and file that will be attached to this e-mail. The attachment (whole e-mail) will be visible in Sent Items folder of your account.
Please let me know if you have any questions
