I am trying to prevent a button click method from executing when grid errors prevent focus change. When the grid has an error, I retain EditMode and the grid retains focus. However, the button click event still executes. The call stack indicates the focus change has triggered the grid.validating event which is cancelled and as expected the focus is retrieved to the grid. However then the MouseUp event seems to proceed and trigger the Button Click event.
I have an ultraGrid control nested in a user control nested in a second user control that also contains various buttons. I use IDataErrorInfo methods to show the error glyph when the cell is in error and retain EditMode. I have attached an event handler for both grid.Validating and the interior userControl.validating both set to cancel with an error. The user control has AutoValidate.EnablePreventFocusChange. I can't find a similar type of property for the ultraGrid. The buttons are set with AcceptsFocus, CausesValidation.
If i just use nested UserControls, set PreventFocusChange and cancel validation, the button click doesn't happen. It seems related to the state of the most nested container control.
Any suggestions appreciated.
Wendy
Hello Hristo,
I've tried the sample and it works as you describe to prevent the button clicks. I now handle this Enter event in my application.
I am just checking about the progress of this issue. Is there anything else which I could do for you regarding this matter ?
Hello ,
Thank you for your details. I was able to see the issue after I have modified my sample with your latest details. When Validating event was cancelled, the form returns the focus back to the UltraGrid, so I have handled Enter event of UltraGrid and have put there the following code (which performing UltraGrid to enters in edit mode like in your scenario):ultraGrid1.PerformAction(Infragistics.Win.UltraWinGrid.UltraGridAction.EnterEditMode);
I have left my validation logic in Validating event. Now if the customer enters an invalid value, he is not able to leave UltraGrid and he is not able to click on any button of the form. Please run the attached sample and let me know if this is what you are looking for.
Thanks for the sample. It works as you describe and the validating event prevents the click events as expected. Unfortunately, my scenario is a little different in that the grid is bound to a MbList and so the failure occurs at the cell binding level and cells will not ExitEditMode when invalid. To simulate this case in the sample, I added the BeforeExitEditMode event handler.
private void ultraGrid1_BeforeExitEditMode(object sender, Infragistics.Win.UltraWinGrid.BeforeExitEditModeEventArgs e){
if (ultraGrid1.ActiveCell.Column.Index == 0 && (int)ultraGrid1.ActiveCell.Value != 0)
e.Cancel =
true; }
You will need to enter edit mode on the cell. Then clicking the button in the User control with the grid is prevented as the grid retains focus. Clicking the button on the form will execute the click event handler even though the validating event is cancelled and the grid retains focus. This is the behaviour I'm seeing in my application. (Note when testing that if there is a break in the code on the validating event handler, the button click will miss the MouseUp and not execute.)
Which version of Infragistics are you using ? I have tested your scenario with Infragistics 11.2 service release 2028. I have created a user control with UltraGrid and UltraButton in it. I handled Validating event of the UltraGrid and canceled the event if the red cell doesn’t contain 0 for value. So if the red cell contain a different value, Click events of my buttons are not raising. Please see the attached sample.
