Usually when I use BeforeEnterEditMode it is to prevent the user from entering into the control by simply canceling. I use it this way because certain themes text display too light when the control is not enabled. I could use read only but most of our customers do not like that style. I cannot get the UltraDateTimeEditor control BeforeEnterEditMode event to fire. No matter what I try. MouseDown does not fire it and changing the date does not even fire the event. All the other Infragistics controls like UltraNumericEditor, UltraCurrencyEditor, and UltraTextEditor fire the event. Should I be using a different event?
I have attached a sample that shows the event is not firing with an UltraDateTimeEditor but that it does work with an UltraCurrencyEditor.
That makes sense. Thank you.
The event never fires because you are settting AlwaysInEditMode to true. So the control is always in EditMode as soon as it is created and never leaves it.
I don't have an override for BeforeEnterEditMode.
You didn't really try to create my scenario. I had already done that. All your sample did was use an UltraDateTimeEditor and inherit it. If that is all I wanted to accomplish I would not have created a user control or inherited it. Most controls if simply dragged and dropped will work. If that is all I wanted I would not have attached a sample to provide insight as to how I am using the control.
Both UltraNumericEditor and UltraDateTimeEditor are built identically except a few designer options. One works and one doesn't. All of the events that I have tested work for UltraDateTimeEditor including KeyDown, MouseDown, and many more. KeyDown was in my sample and it fires every time. The only one I cannot get to work is BeforeEnterEditMode.
Hello Michael,
Thanks for attached sample. I saw the mentioned behavior, but I suppose that something into your code override our default behavior of BeforeEnterEditMode event. I try to reproduce your scenario in a small sample and there everything works properly. Could you please take a look at the attached sample and video file and let me know if you have any questions.
Regards
