Hi All,
This is Chidambaram.
if it is Working fine to use 2 different version of infragistics for 2 difference applications running on the same machine?. The two Infragistic version are 8.3 and 11.1 and OS is Windows XP Professional Service Pack 3.
Please Advice.. Thanks
Hello Craig,
I have already answered to your inquiry in the following forum tread:
http://ko.infragistics.com/community/forums/t/84263.aspx
I'm having a similar issue here. I need to install version 12.1.20121.2024 but the installer will only install the baseline and the most recent (2135). Can you provide me with a private link so I can install 2024?
See this thread to understand my situation:
http://ko.infragistics.com/community/forums/p/84263/420681.aspx#420681
Craig
Hello Todd,
Thank you for the provided details and sorry for the delayed response.
You are correct about the installer. It has only an option to install the latest service release only, or to install just the base version of the product. If you need any specific service release between the first and latest one, I could provide you with a private link in a case especially for you.
I am not a hundred percent sure about the designed behavior of the VS 2010 add-in tool when it comes to manipulating the application that is currently being in source control, so I have created a private case for you - CAS-90764-0WLVBV, so you will receive further assistance from an Infragistics representative through the case.If you have any other questions with this matter, please do not hesitate to contact us.
Thanks Danko,
It would be appreciated - especially considering, I was curious the other day and wondered if the Infragistics Platform installer had an option to present a specific version to install - ran it, guess not - and now it has overwritten the active 2028 build - again making it impossible to use designer in VS2010. Guess I need to uninstall, and reinstall again.
There seriously needs to be a way to tell VS2010 which version is to be used with it... Just some simple app that looks in the GAC, sees which versions are there - and updates VS2010 with the selected license version.
Further proof of need - I tried running the 'Upgrade' option your tools added VS2010 - and get an error- here's the log result content:10:10:45: Running VS2010 Add-in UI Version 11.2.20112.100010:10:45: Gathering volume and assembly information.10:10:48: C:\Projects\Dev\Link\Link.UI\SolutionInfo.cs appears to be read-only or not accessible for some reason.
And Screen shot:
Interesting... gee, could it be because this solution / entire project is under TFS Source control, and unless a file is checked-out - it is Read-only? I currently have this solution open in VS2010 when I ran the upgrader... well, another bug for you guys to fix...
Thanks, Todd
Thank you for your feedback.
If we come up with a solution of this specific scenario within the Visual Studio 2010 designer I will let you know accordingly.
If you have any other questions please feel free to ask.
