2730
Ultra Option Set
When setting "this.ultraOptionSetFilter.CheckedIndex = -1;" to -1, the option set goes null,
so then when i try to set the value to a property or variable i get an error. i am simply trying to clear the option set first then after I do a certain thing, then when I come back around to it, I want ot be able to reselect with out getting the error object has not been set to an instance.
I am going to give an quick example of what I am doing below.
Example:
private void ultraOptionSetSearch_ValueChanged(object sender, EventArgs e)
if (this.ultraOptionSetSearch.CheckedIndex != -1)
////Clear ultraOptionSetFilterBy default if user have selected another item type is selected.
this.ultraOptionSetFilterBy.CheckedIndex = -1;
Now if re execute the logic below the second time, I get a error
Item =
this.ultraOptionSetFilterBy.CheckedItem.DataValue.ToString();
