Hi all,I am facing a strange problem (I am kindof sure that I overlook something).I have an UltraComboEditor and I set its ValueList property to a valuelist.I use an enumerator to create the valuelist setting the DataValue to its integer representation and its DisplayText to the textual representation of each enumerator value.
I use this quite a lot in UltraGrids and normally it works like a charm.
Also the UltraComboEditor shows the correct text and by debugging it I can see that its DataValue is also correctly set.
What I am unable to do is to set the SelectedItem property for the UltraComboEditor.I tried it like this:
cmbAccountType.SelectedItem = cmbAccountType.ValueList.ValueListItems
.Cast<ValueListItem>().First(f => Convert.ToInt32(f.DataValue) == 0);
but it tells me that the conversation between onbject and integer ist not allowed.Also if I am stepping into thie lambda expression I can see that f.DataValue is an object and that f.DataValue.DataValue contains the actual integer value. But I can not get to this...
How should I set the value (I only got the integer because the textual representation is created through localizing the enum) in an easy way?
Any help (and enlightment) is kindly appreciated,cheersAndy
I figured it out,there was an error in the code that generates the ValueLists from enums,everything is fine now.
cheersAndy
