225
UltraTab context menus
I want to beable to right-click on a tab and pop-up a context menu to rename/remove the tab etc.
The built in context menu does't know what tab I have right clicked on? atleast I don't think it does, and it pops up over the shared window which has its own context menu. So I thought I would do it myself with the mouse down event, I have checked for right click only and then call ElementFromPoint() which gets me the UIElement of the tab I clicked.
I can't work out how to tell if its a tab element or how to convert that to an UltraTab object?
Cheers,
Dave
  • 44743
    You have to be careful, because the element returned from ElementFromPoint may be a sub element within the tab element, so you must first get to the tab element, then you can try to access the tab:
    TabItemUIElement tabElement = (TabItemUIElement)elementAtPoint.GetAncestor(typeof(TabItemUIElement));
    if(tabElement != null)
      UltraTab tab = (UltraTab)tabElement.TabItem;
      // Initialize context menu for this tab
    However, you do not need to get involved with the elements if you don't want to. You can just use the TabFromPoint method on the UltraTabControl.
