We have an MDI application that uses an UltraTree object to display hierarchical functions to user. About a month ago, we upgraded our Infragistics components to the latest release, 11.2 CLR 4.0, SR 2028.
We're now experiencing a random error, that appears during mouse operations (mouse move, mouse click) on UltraTree, and that is intercepted by OS as an Unhandled exception:
System.ObjectDisposedException: Cannot access a disposed object.Object name: 'ToolTipFormEx'. at System.Windows.Forms.Control.CreateHandle() at System.Windows.Forms.Form.CreateHandle() at Infragistics.Win.ToolTipForm.CreateHandle() at System.Windows.Forms.Control.RecreateHandleCore() at System.Windows.Forms.Form.RecreateHandleCore() at Infragistics.Win.ToolTipFormEx.set_DisplayShadow(Boolean value) at Infragistics.Win.ToolTip.set_DisplayShadow(Boolean value) at Infragistics.Win.UltraWinTree.UltraTree.get_ToolTip() at Infragistics.Win.UltraWinTree.UltraTreeNode.ShowTooltipIfNeeded() at Infragistics.Win.UltraWinTree.UltraTree.OnMouseEnterElement(UIElementEventArgs e) at Infragistics.Win.UltraControlBase.Infragistics.Win.IUltraControl.FireMouseEnterElement(UIElementEventArgs e) at Infragistics.Win.ControlUIElementBase.ElementEntered(UIElement element, Boolean triggerMouseLeavesOnly) at Infragistics.Win.ControlUIElementBase.ProcessMouseMoveHelper(Object sender, mouseEventArgs e) at Infragistics.Win.ControlUIElementBase.ProcessMouseMove(Object sender, MouseEventArgs e) at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e) at Infragistics.Win.UltraWinTree.UltraTree.OnMouseMove(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseMove(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Could you please help us to avoid this behaviour? If you need details, please ask.Thanks!
Ok. Thanks to Mike who opened a case (I hadn't that time yet..). And thanks to Infragistics staff that worked to find a solution. We're waiting for service release, then. Bye!
Just wanted to let you know I confirmed that this is indeed a bug. It should be fixed in the April service release.
The bug happens when you show a tooltip in one DisplayStyle (like the default style), then try to show a tooltip on the same tree using the WindowsVista DisplayStyle. So it will only happen if you switch styles at run-time after showing a tooltip in the tree at least once.
OK, I see this issue has already been submitted to development.
I uploaded it to case # CAS-85397-BG6V5W
I have attached it here also.
Mike,
I don't see the demo app that you uploaded. Could you try again?
