405
Changing Key in ValueList
I am using a UltraWinGrid and need to set a ValueList to a column, however the Data Source does not have a regular Id, Value but Name,Value, i tried looking for DataMember, ValueMember properties but no luck. i also tried to change Key property no luck again. this is my code:
                UltraGrid grid = (UltraGrid)gridDefinition.Grid;
                ValueList valueList = null;
                if (source != null)
                    valueList = new ValueList();
                    valueList.Key = source.Columns[0].ColumnName;
                    foreach (DataRow row in source.Rows)
                        valueList.ValueListItems.Add(
                            new ValueListItem()
                                DataValue = row[0],
                                DisplayText = row[1].ToString(),
                    grid.DisplayLayout.Bands[0].Columns[columnKey].ValueList = valueList;
