995
Design Setting Changes Not Used in Runtime
I am changing, for instance: the Grid Backgroup color, using the Designer, Control Settings, Ultra Grid, Display Layout, BackColor.  I set to ControlDark and the backgroup show Control Dark.  I save and apply settings.  When I run, the control still shows this as white.  I cannot find any setting that is telling the grid to save/load past run settings,etc.  If there is one, where is it and how do I turn it off?
I have tried digging in to the maze of properties in runtime and the same setting set in code after populating grid also fails, as does, for instance:
Display.OverRide.Appearance.FridayOnly.UserSpecific.OverRide.Bands[0].WhenOnlyOneBand.Appearace.OverRide.BackColor.RegionSpecific.Users.Race.BackColor.LastUsed.OverRide.ColorBlindAccessibilty.WhenTrue = Color.DarkGrey
 Thanks.
