I have a datatable like this :
Quantity Price Date Comment 50 20 10/15 Buy 160 40 15 10/15 Buy 160 60 14 10/15 Buy 160 35 22 10/16 Buy 276 44 16 10/16 Buy 276 78 13 10/16 Buy 276 96 19 10/16 Buy 276 23 2 10/16 Buy 276
I want to see this in a ultragrid where the mother table are
Date Comment 10/15 Buy 160 and 10/16 Buy 276
and the child table are :
50 20 10/15 Buy 160 40 15 10/15 Buy 160 60 14 10/15 Buy 160 and 35 22 10/16 Buy 276 44 16 10/16 Buy 276 78 13 10/16 Buy 276 96 19 10/16 Buy 276 23 2 10/16 Buy 276
I know that I should use datarelation but I don't really know how Thanks fro your help
If this is all in a single table, then you don't need a DataRelation. You could do this with the grid using OutlookGroupBy.
All you have to do is set ViewStyleBand to OutlookGroupBy.
Then use this to group by the Date column:
grid.DisplayLayout.Bands[0].SortedColumns.Add("Date", false, true)
If the two fields are always the same, then you can group by either one. If you need to group by a unique pairing of the values, then you could group by both and create two levels, or you could use a GroupByComparer.
