1149
Put datasource to null
Hi everybody,
some months ago I realized an UltraGridNavigator (you can find it in my files section). It worked fine until today, when I encountered a particular situation that make it to fail.
To react at any ColumnFilter changes, it listen to Property_changed in the following way:
void sourceGrid_PropertyChanged(object sender, Infragistics.Win.PropertyChangedEventArgs e)
    PropChangeInfo columnFilterChangeInfo = e.ChangeInfo.FindPropId(Infragistics.Win.UltraWinGrid.PropertyIds.ColumnFilters);
    if (columnFilterChangeInfo != null) {
       //Do something
so  the navigator could show a Filtered or NonFiltered status.
But what happen if DataSource is put to null?
In agreement with what Mike S. says here:
 http://news.infragistics.com/forums/p/8755/34465.aspx
the layout get reset. That's ok, and also filters get reset, that's absolutely consistent.
The only odd behavior which follow is that the property_changed relative to  Infragistics.Win.UltraWinGrid.PropertyIds.ColumnFilters  do not get fired !
Is this intentional? Why? How can I overcome of it?
Thank in advance.
Gianni
