I have UltraCombos that I bind at run time with a datatable. In the latest release (2034), the ValueChanged event does not fire when the selected row is cleared.
In version 11.1.20111.2026 and previous versions this worked as expected. When the selected value is clear the ValueChanged event fires. This started happening right after the upgrade to 11.2.20112.2034 with no other code changes.
Can you confirm this as a bug or are there additional settings that must be set for changing the value to nothing to fire the ValueChanged event?
Hello Paul,
I have created case # CAS-88549-74D6SZ for you to better assist you with this issue going forward. To access the case, simply log into your IG account and click on My Support Activity.
I am also running into this issue. Is there a hotfix or update that resolves this issue yet?
I will be happy to help you out with this issue.
I have created case # CAS-85719-S2XJX for you to better assist you with this issue going forward. To access the case, simply log into your IG account and click on My Support Activity.
Please let me know if you have further questions in this matter utilizing the case created.
Thank you for your quick reply!
I tried this out and I get the same results.This is clearly a bug and needs to be corrected.
I have forwarded this thread and a sample over to Infragistics Developer Support so they can create a case for you and write this up for developer review. You should be hearing from them shortly with a case number.
