I'm doing an excel export from a simple UltraGrid with one cell. In the CellExportedEventHandler I'm changing the value of the current cell to a new value. If I extract the resulting Excel file and open the .\UltraGridExcelExport_CellExported.xlsx\xl\sharedStrings.xml I can see the new value and the old value too. This is bad in two ways.
Attached you can find a small example project.
It would be nice if someone knows a solution for this problem.
Kind regards
Sascha
Hi Michael,I have tested it with v11.2 and you are right. The issue has been solved with the new version. In fact this is a simple solution but for us it means paying again 800 € for a new licence. :-(Never mind, I thank you for your answer.RegardsSascha
Sascha.
I suggest that you upgrade your application to the latest version of NetAdvantage. I upgraded your sample and tested it with versions 2011 volume 1 and 2011 volume 2 and I did not see the old value in the sharedStrings.xml files but only the new value. Please try this and let me know if it improves things for you.
