830
Stop child property from firing until "+" clicked
I have a 2 Custom objects called BLPerson and BLProject. BLPerson contains a child property called Projects which is a collection of BLProject. Property Projects goes to the database and gets all the projects that person owns.
When I create an instance of BLPerson the Projects property does not fire until it is referenced however if if i point the BLPerson instance to a grid whose DisplayLayout.LoadStyle=LoadOnDemand then the Projects property fires immediatley i.e before the User clicks on the "+" sign to show the Projects child band.
Is there a way to only have the child properties of my object fire when the User clicks on the "+" sign to open them ? Some of the objects contain several children so it is quite an overhead to get the data if its not required.
Thanks john
