880
Issue with an unbound column
Hello:
I am using an unbound column with a Style set to Checkbox to indicate if a User Account is locked or not.
If the Locked_Date is not null, then the user_account is locked and this is checked. Otherwise, it's not checked.
This I do after I fill my dataset. But when I close the form, it tells me that I have changed the data and if I wanted to commit the changes (I've implemented the code that determines if the dataset has changed or not.).
But the problem is that the data has not changed. It's just that I have filled the unbound column with a calculated value.
Any idea how I can prevent it from determining that the dataset has changed since it was filled?
Venki
