5250
ultraCombo DropDown Layout
Hi all
I am trying to build a very simple ultraCombo.
I have a DataTable with some string entries.
I have set DataSource = DataTable.
Now, the DropDown has a header and also the size (width)
does not fit with the ultraCombo control.
How can I do this ?
Just set the dataSource and when the user clicks on the button
the dropDown should be just a list of entries and the width should
be the same width als the ultraCombo.
Thanks and best regards
Frank Uray
I have tried the following:
                this.ultraCombo_ConnectionA_Source_Server.DataSource = GetSQLServers();
                this.ultraCombo_ConnectionA_Source_Server.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDown;
                this.ultraCombo_ConnectionA_Source_Server.DropDownWidth = this.ultraCombo_ConnectionA_Source_Server.Width;
                this.ultraCombo_ConnectionA_Source_Server.DisplayLayout.UseFixedHeaders = false;
                this.ultraCombo_ConnectionA_Source_Server.DisplayLayout.Override.ColumnAutoSizeMode = Infragistics.Win.UltraWinGrid.ColumnAutoSizeMode.AllRowsInBand;
  • 445
    Suggested Answer
    I have a routine I use to do this repetitive task. It takes into account if the width of the text displayed in the drop down as well as one or two columns.
        Public Sub SetDropDownWidth(ByRef oCombo As Infragistics.Win.UltraWinGrid.UltraCombo, ByVal ColumnName As String, Optional ByVal ColumnName2 As String = Nothing)
            Try
                oCombo.DisplayLayout.Bands(0).Columns(ColumnName).Width = oCombo.DisplayLayout.Bands(0).Columns(ColumnName).CalculateAutoResizeWidth(Win.UltraWinGrid.PerformAutoSizeType.AllRowsInBand, True)
                If ColumnName2 IsNot Nothing Then
                    oCombo.DisplayLayout.Bands(0).Columns(ColumnName2).Width = oCombo.DisplayLayout.Bands(0).Columns(ColumnName2).CalculateAutoResizeWidth(Win.UltraWinGrid.PerformAutoSizeType.AllRowsInBand, True)
                End If
                If oCombo.DisplayLayout.Bands(0).Columns(ColumnName).Width < oCombo.Width Then
                        oCombo.DisplayLayout.Bands(0).Columns(ColumnName).Width = oCombo.Width * 0.7
                        oCombo.DisplayLayout.Bands(0).Columns(ColumnName2).Width = oCombo.Width * 0.3
                    Else
                    End If
                End If
            Catch ex As Exception
                HandleError(ex, "modControlLayout", "SetDropDownWidth")
            End Try
        End Sub
  • 5250
    I have got it: I use UltraCombo Editor now :-)
