340
UltraTooltip not loading in first MouseHover
I'm using Infragistics NetAdvantage 2010 in my Winforms application. This is the code for loading a custom tooltip on a button's mousehover.
private void button1_MouseHover(object sender, EventArgs e)
UltraToolTipInfo toolTipInfo = ultraToolTipManager1.GetUltraToolTip(button1);
    toolTipInfo
.ToolTipTextStyle = ToolTipTextStyle.Formatted;
.DisplayStyle = ToolTipDisplayStyle.Office2007;
    toolTipInfo
.ToolTipTextFormatted = "" +
"<p style='color:Black; font-family:tahoma;'>Details:</p>" +
"<p style='color:Black; font-family:tahoma;'>Name: <t style='color:Black; font-family:tahoma; font-weight:bold;'>Sandeep</t></p>" +
"<t style='color:Black; font-family:tahoma;'>Profile: <t style='color:Black; font-family:tahoma; font-weight:bold;'>Developer</t></t> ";
But when I run this, the tooltip won't appear the first time when I do a mouse-hover. It starts coming from the second time onwards. What could be the problem here?
  • 469350
    I don't understand why you are using MouseHover or MouseEnter for this. If you want a tooltip to show up on the control, then you should be assigning it before MouseHover, like in the Form_Load or even at design-time.
    MouseHover is what triggers the tooltip in the first place. So using MouseHover to assign the tooltip to the control is too late.
  • 340
    Verified Answer
    Well I can say this is just a workaround for the time-being.
    I put the same code into the MouseEnter event also, and this thing works! The tooltip is displayed the first time itself.
    Moreover, I'm expecting the actual resolution to this from the Infragistics team.
