I have a VB .Net 2008 windows application using Infragistics V9.1 library. I plan to migrate the entire application to VS2010. Can I still using V9.1 in VS2010 environment?
Also I have a C# .Net 2008 Web application using Infragistics V10.3. I plan to migrate the entire application to VS2010. Can I still using V10.3 in VS2010 environment?
Steve
Hello Steve,
Yes, you should be able to use our controls in both of these cases without any issues. You could take a look at the following page: http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironments.
Please do not hesitate to contact us if you need any additional assistance.
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
Hi Boris,
Thanks for checking. I will do the conversion today. I will let you know if there is any issues that I cannot resolve..
Thnaks, Steve
