240
Integer as string while import data from ultraGrid to Excel
I have a table in database with one integer and one varchar column and in both I'm storing number values. while I'm displaying the same in grid I'm getting integer as string type. so while exporting the same to excel sheet(using  ultraGridExcelExporter) it appears as string type of integer value. So in excel the string type of integer, it will convert into date format by default. I can see it as integer but while i'm trying to upload the same excel to database it covert that value into date format. Please help me on this.
Thanks in Advance.
Kishor Kodakkatil
Software Developer
  • 469350
    Hi Kishor,
    I'm afraid I do not understand what you are asking. If your data source is returning integers, then the grid column data type will also return integers, and these values will be exported to excel as numeric values.
    If your integer values are getting exported as strings or dates, then something in your code must be converting them - or else your data source is returning them that way.
