380
Set form window transparent
Hi
I have a question about the ribbon style. I have generated a ribbon style file but now the form frame is not transparent.
This is a picture of the syle i use:
The form frame should look like this. (Windows 7 style)
You can see the standard from frame is a little bit transparent. Can anybody tell how i can set the frame transparent ?
  • 20872
    Verified Answer
    Hello Alti,
    I have tried a few different style and under my windows 7 the caption area is always using the Aero style of my machine. Does your application prevents in some ways the aero effect? There is also one property of the UltraToolbarsManager component called IsGlassSupported which should also be set to True. If you are able to provide your custom style I will be glad to look further for a way to be able to use the machine Aero semi transparent settings of your Windows 7.
    If you have any other questions please feel free to contact us.
