1445
How to set the Value of a value list?
I am using the UltraGrid. I have a column that has a style type of dropdown list. That list has a valuelist that is tied to ultra drop down. I can get everything to come up ok. But I run into an issue when another column sets that value. How do I set that dropdownlist for that column in the grid so it shows the text of the dropdown and the not the key.  I started out set .Value and that did not work.
  • 71886
    Hello apalcer,
    I wanted to know if you were able to solve your issue based on these suggestions or you still need help. Please let me know.
  • 469350
    Suggested Answer
    I'm not sure I understand your question.
    IF you have a ValueList attached to a grid column (or cell), then Value of the grid cell is matched up to the DataValue of one of the items on the list.
    So, for example, if you have a ValueList like this:
    DataValue     DisplayText
    1                     "Apple"
    2                     "Banana"
    3                     "Cherry"
    To "select" an item from the ValueList in code, you would set the Value property of the cell to 1, 2, or 3.
