1833
Border width issue...
So, I'm writting a new application, based on an existing application I have that utilises theUltraWinToolbBar manager in order to get a a blue theme.  I'm using the latest release of v9.2 of the Infragistcs controls and VS2008 on a windows 7 machine. Both applications use the same .isl file which is pretty much the same as one provided with the examples with some minor tweaks.
The issue I find is that on the1 application the bordersd are nearly twice as thick as the borders on the other applicaiton. Both applications use an MDI container and both forms listed below are of the same FormBorderStyle, 'Sizable'.
I cannot see any unusual settings, if I copy 1 form from the applicaiton showing thin borders to the one showing fat borders, the borders do indeed become fat. Which kinda sucks for an MDI child form!
New App - Fatter: -
Original App - Thinner: -
Now I will put my hand up here and admit that the application showing thin borders, the one I consider correct, is running v9.1.20091.2012 of the Infragistics controls, where as the other is using v9.2.20092.2119.
Is this a bug in the old one? is there anyway to stop these borders being fat and looking a bit shoddy? I read that this is not easily tweaked without manually drawing the borders.  which seems overkill when I just want a thinner border like the example above.
Thanks!
  • 20872
    Hello Aim123,
    I am still following this forum thread.
    If you have any other questions or need further assistance please feel free to let us know.
  • 20872
    Hello Aim123,
    I have been looking into this forum thread, and in order to make the border look thinner you could use UltraFormManager, which is available after NetAdvantage 2010 vol.2
    If you have to use an older Infragistics assemblies, may I ask for a simple sample application which includes the desired app style, so I will investigate it further if it is possible to make the border thinner. I have tried it, and most probably the border appears wider because of the Windows 7 theme which has similar wider borders, when the window is sizable.
    If you have any other questions with this matter please feel free to let us know.
