Hi
Although I've searched through the forum and even found a couple of releated threads the solution is still not quite clear for me
We can easily make a cell in UltraWinGrid to be a drop down list using at least three Infragistics controls. But this cell will accept only one value selected from a list.
What if I want to be able to select from multiple values in the drop down list and show selected values as comma separated strings in the cell.
I didn't get how I can do this usign out of the box capabilities. I still can do this with custom coding but if there is something already inbuilt I want to leverage it.
We use Infragistics 2011.2
I am not able to get this behavior. Could you please try to attach if possible a small sample project reproducing the above mentioned issue, I will be happy to take a look at it.
Hi, I am able to get same functionality of multiple dropdown in ultra combo editor,but when i am trying to bind values from DB ,then i am not able to set checkbox based on logic. I have tried setcheckedstatus,values evrything.I have created a saparated unbound column also in ultracombo but that also not working for me. Please help me to sugegst solution for this as i can see that checkeditem count while setting values from debugger but still checkboxs are unchecked and selected values are not showing in wingrid cell where i am using ultracomboeditor as editor component.
Need help asap.
This works, samples were very helpful. Thanks
So the outcome is
This works fine with UltraComboEditor
This doesn't work that well with UltraCombo because it requires you to mainain selected/not selected state in a separate bool column. While this is fine for a standalone UltraCombo, using it in as an editor for UltraGrid is not recommended
And this is not supported with an UltraDropDown at all, only with custom coding.
Thanks a lot guys. I'll try this out and post results here.
