160
System.ArgumentException when interacting w/ Column Chooser of disposed grid
I can cause an unhandled ArgumentException if I select a band in the Column Chooser dialog of a grid that has been disposed and released from memory.
Why doesn't the grid close the Column Chooser when the grid's Dispose() method is called?
How can I force the grid to close the Column Chooser?
System.ArgumentException:
CurrentBand must be a valid band from the SourceGrid.
Parameter name: CurrentBand
Exception Properties:
ParamName: CurrentBand
Stack Trace:
   at Infragistics.Win.UltraWinGrid.UltraGridColumnChooser.set_CurrentBand(UltraGridBand value)
   at Infragistics.Win.UltraWinGrid.UltraGridColumnChooser.comboBoxBandSelector_SelectedIndexChanged(Object sender, EventArgs e)
   at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
   at System.Windows.Forms.ComboBox.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
