Can I and where can I can the property to alter or add color to top of the active tab. The coloring is there when the "Style" property is set to "Default". But once i change the "Style" mode to something other then defualt I lose it. Is there a why to change the style and keep the highlight??? Here is a pic to show you what I mean.
Thanks!!
Hi vravo,
This particular highlight, aside from being displayed only on Windows XP systems, is only available when using the default tab display style.
It may be possible to create a custom appearance similar to this with a DrawFilter implementation to use with other display styles, but the functionality is not extended by the TabControl.
If you have any further questions regarding this issue, please let me know.
Sincerely,Chris KDeveloper Support EngineerInfragistics, Inc.www.infragistics.com/support
