Hi ,
I would like to have my x and y axes like this in a splinechart:
An idea how to do that in c# ?
You could achieve this if you change the location of your axis in the FillSceneGraphe event. Please take a look at the attached sample for more details and let me know if you have any questions.
Regards
Thanks it is almost that , however, my axis are not centered in zeros , it is the same in your sample. Can you please make it to cross X = 0 and Y = 0 please ?
Maybe one possible approach to achieve desired behavior could be if you are using FillScenGraphe event and include this piece of code:
private void ultraChart1_FillSceneGraph(object sender, Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs e) { foreach (Primitive item in e.SceneGraph) { if (item.GetType() == typeof(Line) && ((Line)item).lineStyle.DrawStyle != LineDrawStyle.Dash) { if (((Line)item).p1.X == ((Line)item).p2.X ) { ((Line)item).p1.Offset(this.ultraChart1.Width / 2, 0); ((Line)item).p2.Offset(this.ultraChart1.Width / 2, 0); } else { ((Line)item).p1.Offset(0, -this.ultraChart1.Height / 3); ((Line)item).p2.Offset(0, -this.ultraChart1.Height / 3); } } Text pl = item as Text; if (pl != null && ((Text)item).labelStyle.Orientation == TextOrientation.VerticalLeftFacing) { ((Text)item).bounds = new Rectangle(((Text)item).bounds.X, ((Text)item).bounds.Y - (this.ultraChart1.Height / 3), ((Text)item).bounds.Width, ((Text)item).bounds.Height); } if (pl != null && ((Text)item).labelStyle.Orientation == TextOrientation.Horizontal) { ((Text)item).bounds = new Rectangle(((Text)item).bounds.X + this.ultraChart1.Width / 2, ((Text)item).bounds.Y, ((Text)item).bounds.Width, ((Text)item).bounds.Height); } } }
else
also you could used Range properties of your X and Y axis. Please take a look at the attached sample for more details and let me know if you have any questions.
Thanks for your sample, it is almost that, in addition I would like to have the scale of each axis close to the axis like this :
Could you please review the sample attached to this post and see if it meets your requirements - It works for SplineChart also.Please feel free to let me know if I misunderstood you or if you have any other questions.
