I have placed 3 masked edit tools in a ribbon group. I have a caption and edit portion. Is it possible to set the position and size to align all tools. The length of the captions are different and the edit portion should be aligned to the same position and size.
If this is not possible, any others suggestions to achieve this? Should I use ControlContainer Tool?
Thanks for your help.
Regards
Markus
Hello Markus,
I will be happy to assist you with your question.
You should be able to use the Width property for the maskedEdit to change the width of the tool. To learn more about this property, please visit our online docs here. Also, please note that you can use the designer to drag and drop tools placed on the Ribbon to new areas of the Ribbon. If you wish to have more flexibility with this positioning of tools, I recommend utilizing the ControlContainerTool to add a ultraPanel onto the Ribbon. This will allow you to place any control the Ribbon via the Ultra Panel with the added benefit of settings its location property relative to the ultraPanel.
Please let me know if you have additional questions regarding this matter.
