725
WinTab: initial tab activation
I have created a frame (frmRGC_Interface) with a pane which is the container for a user control. I have five different user controls, each of them with a UltraTab control "tabInterface" containing the same tabs.
The parent frame (frmRGC_Interface) which contains the pane is replacing the displayed user control within the pane, so I will dispose the last used user control before I display a new one. The idea is to keep the last activated (selected) tab.
I tried to do the following:
-- in the user control's dispose event, I set a friend shared variable "frmRGC_Interface.curTab" to the key of current active tab like:
frmRGC_Interface.curTab = tabInterface.ActiveTab.Key
-- in the new event of the user control, I set the tab like:  tabInterface.Tabs(frmRGC_Interface.curTab).Active = True
 Problem: each time the NEW event is processed, the system always reactivates the first tab of tabInterface.
How can I keep the activation of a tab (or transfer the actviation status between user controls) ?
Stephan
