Ultra grid 1st click should behave as cell selectable (with cell blue color as selected). 2nd click will behave as Editable. How to do that behaviour in ultragrid
Its really helpful for me to achieve the functionality. Thanks for your help.
Hello ,
Here is one possible implementation of how you could achieve your goal.
Please let me know if you have any further questions
Any updates regarding this scenario.
I would this scenario which i am using in DataGridView to be implemented using UltraGrid.
When the user first clicks or selects on the cell - The ultragrid should saw the cell as seleted. like it indicates with some cell back color as blue.
When the user clicks second time (its not a double click) - second single click on the same cell - should make the cell as editable. The second click is a single click not a double click.
How would i achieve the same. possibly by setting the properties of ultragrid if possible other wise through code.
Please share a sample or existing sample details.
I just wanted to know if you were able to solve your issue based on my suggestions or you still need help?
Just let me know.
Thank you.
