Want to easily populate a WinComboEditor with an enum?
heres how...
In a suitable place on your form code
MyUltraComboEditor.PopulateWithEnum<
MeasurementTypes>();
where MeasurementTypes is defined as the following enum;
public enum MeasurementTypes{ [Description("each per item etc")] Discreet, Linear, Area, Volume}
You can also use the Description Attribute for a more verbose description of the enum value with spaces in it!
I inherited and modified the ComboEditor as such;
public class ipUltraComboEditor : Infragistics.Win.UltraWinEditors.UltraComboEditor {
public void PopulateWithEnum<T> () { Type enumType = typeof(T); if (enumType.BaseType != typeof(Enum)) throw new ArgumentException("T must be of type System.Enum"); string desc;
foreach (T item in EnumToList<T>()) { FieldInfo fi = item.GetType().GetField(item.ToString()); DescriptionAttribute[] attributes = (DescriptionAttribute[])fi.GetCustomAttributes( typeof(DescriptionAttribute), false); if (attributes != null && attributes.Length > 0) desc = attributes[0].Description; else desc = item.ToString(); var vli = new ValueListItem { DataValue = item, DisplayText = desc }; this.Items.Add(vli); } }
public static IEnumerable<T> EnumToList<T>() { Type enumType = typeof(T);
Array enumValArray = Enum.GetValues(enumType); List<T> enumValList = new List<T>(enumValArray.Length);
foreach (int val in enumValArray) { enumValList.Add((T)Enum.Parse(enumType, val.ToString())); }
return enumValList; } }
The ComboEditor can be databound as normal and saves the integer value back to the data source.
Let me know if this was useful!
