1635
How to add maximize box to floating window.
I am using both UltraDockManager and UltraTabbedMdiManager. In the UltraTabbedMdiManager, I select a tab and then float, but the floating window doesn't have maximize box like this.
Is there any option to add maximize box to floating window like below the picture?
Parents
  • 48586
    Verified Answer
    Hello ,
    As far as I understand you are trying to mimic behavior of Visual Studio 2010, where you could maximize floating windows. The Maximize/Minimize buttons on the dock pane  are used to maximize/minimize a control pane within a group pane. If there is only one control pane within the group pane, these buttons will be disabled. But you could achieve a behavior very close to this of Visual Studio, if you add a button with creation filter to the floating window, and on click of this button to resize the floating window to occupies the screen. I have implement my suggestion in a small sample, please see attached sample.
    More information about creation filter you could find on the following link:
    http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/Win_Creation_Filter.html
    I hope that this will helps you
    90719.zip
Reply Children
No Data
