I using NumericSeries for AREA and BAR charts (composite chart). The datatable consists of huge records (nearly 1000 rows present in the datatable. i.e X-axis and Y-axis combination points are nearly 1000 points).
The Problem here is, when I bind this NumericSeries with the chart, the graph seems to be compressed. So I can't able to view the actual size of the graph.
Even though I using the layers scroll scale to visible, its not working out.
Please refer the screen shot.
Raaj
Helo Raaj,
Let me know if you have any questions
Regards
I made small modification in my previous sample and I include 1000 rows in dataTable which will be ploted in the chart. Also I`m using Scale property and everything seems to work properly. Could you please take a look at the attached sample for more details and let me know if you have any questions
