I build a small application with drildown from Column graph to PieChart using the DrillElement.
I use a cmd to get same data to DataSource.
But the are two small problem:
1) The PieChart repeat the same color in same drillelement( graph)
2) I don't understand why the drillelement react like the parent graph, i.e , goto other drillelement.
Thanks in advance.
Miguel Jerónimo
Hello Miguel,
Have you been able to resolve your issue ? Did you try my suggestion with CustomPallet ? Let me know if you have any questions.
Regards
The mentioned behavior is exprected, because these are default settings. Maybe one possible approach to change this behavior could be if you are using
this.ultraChart1.ColorModel.CustomPalette
Could you please take a look at the attached sample where I`m using this approach and let me know if you have any further questions.
