1935
UltraGrid - Band[0] to be summery of Band[1]
i'm not sure if i should be asking this but i'll give it a try and you can feel free to say "forget it"
is there a quick way to have the Band[0] be a summery of Band[1]  (parent/child)? instead of me doing it manually for each column
part of the Band[1] columns are Text data and part of them are Numbers data (represented as strings)
at the moment i am binding a dataset that has 2 tables with DataRelation between them  most of the columns are the same and visually i would like the band[0] cells will be the summery of the band[1]  . but i dont care about the band[0] dataset wise , i only care about the band[1]
thanks
