We've got an issue where appointments that start on one day and end the next display funny. If the appointment is >= 24 hours then appointment spans the days in the month view. If the appointment is < 24 hours, it looks like two different appointments. I've attached a screenshot example of what's going on.
The first appointment starts at 9am on the 14th and ends at 9am on the 15th.
The second appointment starts at 9am on the 16th and ends at 8:59am on the 17th.
Any ideas what I'm missing?
Hello CMAlora,
I tried this and it always works fine for me so I attached my sample to this post for you. Please review it and feel free to let me know if I misunderstood you or if you have any other questions.
Hmm, I'm using VS 2008 and can't open that solution. What version was that created in? Also, I guess I should've mentioned we're using Infragistics NetAdvantage 2005 Volume 3 CLR 2.0
This version is not supported anymore, please take a look at the following link: http://ko.infragistics.com/support/product-lifecycle.aspx.
This issue must have been fixed sometime ago, because it works ok for me in v12.1 of Net Advantage. So what you could do is to download to trial version of 12.1 Net Advantage and test your application against it.
Thanks for your help. At this time, I haven't had a chance to test out the latest version of infragistics. As much as I'd like to, it seems that migrating our project is not on the table at the moment.
Thank you for the feedback provided, please feel free to let me know if a question about our toolset comes up on your mind.
As an update. I installed the latest version of NetAdvantage and the problem went away. So clearly it's an issue with the older version. Thank you.
