I have turned off expansion indicator and RowConnectors. This is what I am left with...the white gap on the left needs to be gone. Any help is appreciated.
Thank you for your feedback. Please let me know if there is anything else that I could do for you.
Thank you for using Infragistics Components
I see it working now in your sample so something else must be stopping my code from working. So your code is indeed doing what I need it to do.
Let me start from scratch and see if I find my problem.
Thanks a lot for helping. I will post again when I get it working.
thanks
-Ken
Thanks for you effort but you still aren't understanding.....Your grid does the same thing.
When you hide the expansion icon and the row connectors on a grid, the area where they are located still shows up and isn't controlled by the Indention property. How can I get rid of that?
The area marked below is what i want to remove. I already have Band[0] Indention set to 0 and Band[1] Indention is set to 30. That is what I want....BUT I need to remove the area where the expansion icons and connectors are not showing. Could I do this with a DrawFilter? and what UI objects would I be looking to get rid of.
Anyone?
Hello ,
You should set Indentation of bot bands in order to remove the white gutter. I have create a small sample in order to illustrate how changing of Indentation of different bands affects the other bands.
Please let me know if you have any further questions or if I am missing something
That is true, but it doesn't remove the white gutter where the row expansion icons normally shows up.
I want to remove the white area on the right that isn't part of the rows.
