Hi
I can not find a way to set the backgroundImage for the Panel (Inbox Panel)
I have also tried adding the backgroundImage property in ISl file not working for the panels ?
Is there is a way to set background image for panels ??
Hello coldice,
Thank you for the feedback. Please do not hesitate to contact us if an issue comes up.
Dear Boris,
Thanks for asking. It will a bit problem to change the panels in 100+ forms :) .. so probably for styling we will go with the bg colors only not the image for the panels.
Thanks.
Please let me know if this is not a good enough solution for you.
Dear Mike,
Thanks. I will try to find a work out, but dont want to change panels to ultrapanels in whole application.
I said Inbox Panel :P ... inbox panels can only be the .net control panels.
