Forgive my ignorance but which control should i used to view my existing PDF files and allow user to print it from there?
Thanksmiztaken
Hello ,
After looking into this and doing some research, "pdf viewer" has been determined to be a new product idea. You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
There are many benefits to submitting an product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thank you for contacting Infragistics
i have tried many pdf viewer vb.net,including adobe. i end up uisng this app to view pdf files. it is simple and rather efficient for me . hope it is what you are looking for.
Thank you for your feedback and for sharing this with us. We believe that the other community members could benefit from such threads.
Please feel free to let me know if a question about our toolset comes up on your mind.
Thanks for the reply. I ended up using Adobe Reader ActiveX Control.All you need to do is reference this in your project and then drag and drop the control.
Then you can load the pdf using following code:-
this.activexpdfreader.LoadFile(dfpFilePath); this. activexpdfreader.show();
where activexpdfreader is an instance of adobe activex control (dragged and dropped)
thanks
In windows apps, I've just used the System.Windows.Forms.WebBrowser control to view PDF's. You can load one up using the Navigate method which takes the filename of the pdf as a parameter.
Matt
