I am wondering if we can do multiple inheritance on the style set.
<styleSet name="Header" basedOn="dataentry" />
using basedOn keyword we can do inheritance but can we inheritance 2 stylesset,
may be like
<styleSet name="Header" basedOn="dataentry, main" />
where main is another styleset
HI
thanks, its all fine.
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
Thank you for using Infragistics Components
If you modified the XML of the isl file, it will be corrupted you wouldn’t be able to use it properly. If we assume that multi-inheritance of style can be done, how the resulted style will appear if both its parents modified same appearance objects ?
What I could suggest you to do in your case is to create your base style set and to use it as base style for your other stile sets.
